Eng: Motherboard s5520ur need a RAID controller which supports SAS hard disk volumes 1,8Tb, currently worth Raid Controller RS2BL080 he does not find them. Tell me which controller is suitable for this motherboard?
RUS: Материнская плата s5520ur нужен RAID контроллер который поддерживает жесткие диски SAS объемем 1,8Тб, на данный момент стоит RAID контролер RS2BL080 он их не обнаруживает. Подскажите какой контроллер подойдет для этой материнской платы?
You can find the compatible raid controller for this board in the following link:
http://ark.intel.com/products/36456/Intel-Server-Board-S5520UR# @compatibility http://ark.intel.com/products/36456/Intel-Server-Board-S5520UR# @compatibility
You can use the RT3WB080
the tested hard drive list for the controller is in the following link:
http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/rt3wb080/sb/rt3wb080_thol_v62.pdf http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/rt3wb080/sb/rt3wb080_thol_v62.pdf
дело в том что на странице есть совместимое оборудование, но на RAID контроллере нет описание и поддержки жестких дисков 1,8 Тб, подскажите какой конкретно контроллер будет работать, в данном случае интересует http://ark.intel.com/products/59674/Intel-RAID-Controller-RS25NB008 этот
Hello Ivan,
The SAS RAID controllers listed in the link would support the capacity of the drives you are using. Is there any other particular requirement besides the size of the drives that we need to consider?
Hello, Ivan,
We just wanted to follow up on your request. We would like you to provide us with your hard drives' part number / model to validate if they are supported by our Intel Raid Controllers.
As we tried your scenario at our lab, and, the Intel Raid Controller RS2BL080 was able to read disks which capacity was higher than 2 TB (Hard drive part # ST4000NM0033)
We will be looking forward to your reply.
Fernando M
Здравствуйте, Ivan,
Мы просто хотели, чтобы следить за вашим запросом. Мы хотели бы вы, чтобы предоставить нам ваших жестких дисков "Номер в каталоге / модели для проверки, если они поддерживаются нашими RAID-контроллеры Intel.
Как мы пытались ваш сценарий в нашей лаборатории, и, то Intel RAID-контроллер RS2BL080 был способен читать диски, мощность которого была выше, чем 2 ТБ (Жесткий диск часть # ST4000NM0033) Мы будем с нетерпением жду вашего ответа.
С Уважением,
Fernando M
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
