Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4661 Discussions
Need step to install RHEL7 without Linux system help like mount -o loop command,
Ishai4
We have Intel s2600cp2 board with 500GB*3 HDD, Configured Raid-5 onboard RSTe. I want to know how to give the driver? Want to know step by step RHEL 7 Installation. In DUD Megasr Given the Driver Step. I dont have Linux Plate from to run command mount -o loop command. I have windows platefrom.
David_A_Intel
I was checking the information for the http://www.intel.com/support/motherboards/server/sb/CS-033343.htm validated Operating System for this controller (RSTe) and I could not find Linux-based Operating Systems.
Typically, you might want to use our ESRT2 controller instead or to upgrade to a hardware RAID solution.
