Intel(R) RAID Controller SRCSAS18E
Please help me to understand the meaning of controller information message (content enclosed).
Does it mean that Disk Drive is faulty and need to be replaced or does it mean that everything is fine.
Thx
Arvidas
ID = 78
SEQUENCE NUMBER = 114140
TIME = 24-05-2010 01:18:20
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 0-3:1:3 - No defect spare location available, CDB = 0x2f 0x00 0x07 0x88 0xb0 0x00 0x00 0x10 0x00 0x00 , Sense = 0xf0 0x00 0x04 0x07 0x88 0xb4 0x80 0x0a 0x00 0x00 0x00 0x00 0x32 0x00 0x9d 0x80 0x00 0x97
ID = 77
SEQUENCE NUMBER = 114139
TIME = 24-05-2010 01:18:18
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Ports 0-3:1:3 - No defect spare location available, CDB = 0x2f 0x00 0x07 0x88 0x90 0x00 0x00 0x10 0x00 0x00 , Sense = 0xf0 0x00 0x04 0x07 0x88 0x93 0xcd 0x0a 0x00 0x00 0x00 0x00 0x32 0x00 0x9d 0x80 0x00 0x97
ID = 76
SEQUENCE NUMBER = 114129
TIME = 24-05-2010 01:08:57
LOCALIZED MESSAGE = Controller ID: 0 Patrol Read started
- Tags:
- RAID
Here is what I get from Google:
No Defect Spare
Location AvailableIndicates that the Reassign Block Command cannot successfully complete because allavailable spare sectors have been used. A Low-level format should be done ignoring the grown defect list and the drive retested. If no errors occur the drive is serviceable.
Dear Edward,
thank you for your answer, it let me understand what is happening.
I can recall the story now.
Having received the trouble beep I have launched Intel RAID Web Console and did find a "foreign configuration drive".
Now I can assume that the controller kicked out the drive and consumed the global hotspare drive.
By then I have deleted "foreign drive configuration", configured drive as independant volume, run testing and received the information messages in matter.
Formating the disk and diskchek did not showed any problems.
However my feeling is that it would be not a good idea to use this drive in company critical array, e.g. as hotspare drive.
I would appreciate your advise:
- if I could ignore the story above and use the disk as no critical errors are received (information message only);
- if this is sufficient reason to claim a warranty replacement.
best regards
Arvidas
If I were you I wouldn't take the risk - after all the data on it is more important than the disk itself.
