Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
On the motherboard S2600TPR Can i using the riser slot 4 for a board PCIe Gen2 x4 card?
ATurc3
SergioS_Intel
Hello ATurc3,
The Riser slot 4 connector of the Intel®Server Board S2600TP, is a PCIe*x16 and it should support the PCIe Gen2 x4 card; however, we do recommend contacting the card manufacturer and check with them for any type of limitation or compatibility issues with PCIe*x16 slots.
For more information in regards the PCIe* x16Riser Slot 4 Connector, please check page 81 on the technical product specifications:
https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/S2600TP_HNS2600TP_TPS_R1_48.pdf
Sergio S.
A Contingent Worker at Intel
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
ATurc3
can i using the " Rise Card for Riser Slot #1" in Riser Slot #4?Rise Card Solt 1.png
The pins of Slot are different
ATurc3
Can i installed the borad Four-channel HD capture card Part number: 11090 ( http://www.magewell.com/products/pro-capture-quad-sdi ) in Riser slot 4?
SergioS_Intel
Hello ATurc3,
We do recommend contacting the card manufacturer here so they can provide you with compatibility information. You can additionally check Tested Hardware and Operating System Lists so you can check the list of supported cards for your Intel® Server Board S2600TPR.
Finally, can you please elaborate on your first question: "can i using the " Rise Card for Riser Slot #1" in Riser Slot #4?"
Sergio S.
ATurc3
The "Rise Card for Riser Slot # 1" is an Intel card made for the S2600TPR motherboard for use in the Rise Slot # 1, I want to use this card in "Rise Slot # 4", but is not specified in the data sheet.
SergioS_Intel
Hello ATurc3,
Upon checking the TPS of the S2600TPR it only comes with 2 riser card slots
Can you please clarify what do you mean by Rise slot # 4? Are you referring to the  PCIe* x16Riser Slot 4Connector? If so, can you please let us know what you are trying to accomplish?
Sergio S.
ATurc3
I want install the borad Four-channel HD capture card Part number: 11090 ( http://www.magewell.com/products/pro-capture-quad-sdi ) in Riser slot 4.
SergioS_Intel
Hello ATurc3,
Thank you for the clarification, please contact the manufacturer of the card so they can provide you compatibility information.
Sergio S.
SergioS_Intel
Hello ATurc3,
I am following your question and we would like if you need more help.
Sergio S.
ATurc3
hi,
thanks for answer, but if not exist the board adapter for "Riser Slot 3" and "Riser Slot 4" i have to build the board adapter
SergioS_Intel
Hello ATurc3,
No problem, we are going to close this thread; however, if you need further help, please contact us back.
Sergio S.
