Similar problem.
Fans are noisy. One of them broke down because of this. I had to change it.
I send all the data that I could collect .....
https://yadi.sk/d/hYezB_wN5iGQ6w
I updated the BIOS on BIOS_R02.06.0007_package_Romley_Platforms, but it did not help.
Please help .... What makes them spin so much? Where is the breakdown? What needs to be replaced?
I suspect that the fact is that the system thinks that some fans are not spinning. Although the system is connected to a total of 5 case fans and two in the power supply.
The problem was originally. At the time of buying.
I turned to the then still working Russian-language forum, where I was provided with a link to the firmware update. The update then solved the problem.
Three years everything was fine. Periodically (semi-annually), the coolers were started to rotate at an increased speed, but this was caused by the failure of the power supply units (there are two installed). The LED of one of them began to glow orange. But about three months ago, the problem was out of control.
I send a photo of the memory module. They are installed four on one processor. The slot for the second processor is empty.
Yes ...., fan speed has decreased !!!!
Thank....
However, there is an old problem with power supplies.
One of them flashes green.
There are triggers in the Dashboard.
Maybe this is not critical, but still I would like to understand what it is and whether it can be fixed.
I send a report after running UpdateBMC.nsh and UpdateFRUSDR.nsh
Power supply places changed.
The situation has not changed. The LED flashes on the left. So the power supply is not to blame.
Summary in Active System Console:
I removed the PSU on the right, started the server, waited for Windows to load. LED flashing has stopped.
But when I put the PSU back in, the flashing of the left LED resumed.
No questions yet, thanks ....
Coolers are noisy again. BIOS flew apparently.
Please give a download link without FRUSDR
