Installed the above server early August for a customer, three times how I have received a call that the case fans are all running at full speed. Twice when they came in to the office for start of the day, once when they came back from lunch.
Windows is fully up and operational. There is no evidence the server rebooted though both times it occurred in the morning it was after Microsoft's monthly Tuesday updates.
A reboot resolves, however the customer literally freaks out each time and wants a warranty replacement, they do not seem to understand it is not a defective unit.
When I build the unit, I updated all the Intel software (drivers and BIOS), today I look and there is only a "Power budget and thermal configuration tool" under updates, nothing else. and it is an .xlsm file. I don't have Excel on a server.
You can download the https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23126&lang=eng S2600 BIOS and Firmware Update, Configuration Utilities and run SEL Viewer to check for errors.
I cannot get "selview" to run. I it is not a recognized command. I think I followed the instructions on the TXT correctly. Step 5 worked, but running it in CMD mode did not. I was running CMD as Administrator.
There are two different versions of SELVIEW, depending on which BIOS and firmware you're running.
Try this version from https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21059&lang=eng&wapkw=configuration+utilities Download Center , and see if it works on your board.
