Good day.
First thank you to everyone who help making this forum a reality.
This is my first time here, and hopefully someone can assist me.
I have a S2600CO Server board.
I am looking at the following chassis: P4308XXMFGR.
I need to know what connectors comes with the power supply.
If I found the right technical specs document on the intel website, and understood it properly, this power supply comes with only 2 24 pin power connector.
If that is correct, what do I need to get to have the following configuration:
4 sata and 1 pata connector or 2 sata and 3 pata (I have a converter cable for 2 sata to pata)
I absolutely need 2 6 pin PCIe connector for a video card (Amd Firepro W8000).
I need to have those connector plus all the basic connectors for the S2600CO server board.
Thank you all for your help.
See the chassis http://www.intel.com/support/motherboards/server/p4000m/sb/CS-033329.htm Technical Product Specification section 2.5.2.2.
I also have a SC5650WSNA chassis but have been unable to get the fan control working.
