Server Products
4952 Discussions
Problem booting Intel s5520sc Motherboard.
My computer doesnt boot, and the status led in the back side of tower is ambar.
I fully followed all instructions from the doc's to make the ensamble.
HARDWARE:
ANTEC P193 EXTENDED-ATX TOWER
2 X Intel Quad-Core Xeon E5520 / 2.26 GHz
2 X Intel Thermal Solution STS100C
2 X ASUS GeForce GTS 250 512Mb DDR3
3 X 2 GB Kingston - DIMM de 240 espigas - DDR3 - 1333 MHz / PC3-10600
Antec 650W Power supply
1 X 1.5 TB SEAGTE HD SATA
1 X DVDR
What should be the problem?
M
KAMALANATH_N_Intel
Are you getting any beep codes? if yes tell me the interval of beep..
BTW, check for the compatibilty using the below link .
http://ark.intel.com/Product.aspx?id=36600 http://ark.intel.com/Product.aspx?id=36600
I tried again with a 1200w power unit but still tyhe same 1 5 4 4 beep code.
The second CPU 8 Pin EPS is connected to a 4 to 8 Pin switch.. is it ok?
M
Edward_Z_Intel
I'd suggest you start with one processor first.
yes, beep code is :
1 5 4 4
can help ?
