My computer doesnt boot, and the status led in the back side of tower is ambar.
I fully followed all instructions from the doc's to make the ensamble.
HARDWARE:
ANTEC P193 EXTENDED-ATX TOWER
Intel s5520sc Motherboard
2 X Intel Quad-Core Xeon E5520 / 2.26 GHz
2 X Intel Thermal Solution STS100C
2 X ASUS GeForce GTS 250 512Mb DDR3
3 X 2 GB Kingston - DIMM de 240 espigas - DDR3 - 1333 MHz / PC3-10600
Antec 650W Power supply
1 X 1.5 TB SEAGTE HD SATA
1 X DVDR
What should be the problem?
M
Are you getting any beep codes? if yes tell me the interval of beep..
BTW, check for the compatibilty using the below link .
http://ark.intel.com/Product.aspx?id=36600 http://ark.intel.com/Product.aspx?id=36600
I tried again with a 1200w power unit but still tyhe same 1 5 4 4 beep code.
The second CPU 8 Pin EPS is connected to a 4 to 8 Pin switch.. is it ok?
M
Looks like issue with PSU..
1-5-4-4 Power control fault (power good assertion timeout).
please use only the supported PSU...
http://download.intel.com/support/motherboards/server/s5520sc/sb/e39545_004_s5520sc_service_guide.pdf http://download.intel.com/support/motherboards/server/s5520sc/sb/e39545_004_s5520sc_service_guide.pdf
http://ark.intel.com/Product.aspx?id=36600&code=Intel%c2%ae+Workstation+Board+S5520SC http://ark.intel.com/Product.aspx?id=36600&code=Intel%c2%ae+Workstation+Board+S5520SC
I didnt get your comments proper.. can u pleae throw more light.. on how you connected the CPU 2.?
yes, beep code is :
1 5 4 4
can help ?
