I have Intel® Server Board SE7500CW2 server. I need to install windows server 2003 standart on it. I download drivers from intel's web site for this product and tried to install. I loaded them during setup by pressing F6. And i can see the local disks, and able to merge, delete, create partitions. Then system loads installation files to the hdd. After that, i see such message on the screen:
Setup cannot set the requared Windows configuration information. This indicates an internal setup error. Please contact your system administrator. As i'm a system administrator in my company, i myself wondering why this is so. :-)
Please help me...
The Microsoft article at http://support.microsoft.com/kb/316425 implies that it is something to do with the hardware. I see on http://www.intel.com/support/motherboards/server/se7500cw2/sb/cs-006876.htm that Windows 2003 Enterprise was the tested version - do you have a copy of that?
As you see, i tried to install wind2003ent edition. And this OS is supported by this server. However, i'm still unable to be successed.
Even Enterprise fails, huh? Are there any other add-in cards you could remove? Maybe there's something else interfering with the installation.
Have you checked through the known issues at http://www.intel.com/support/motherboards/server/se7500cw2/index.htm ?
