Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4657 Discussions
Problem with replace LSIiBBU01 on RAID Controller SRCS28X
Good day!
I have Intel RAID Controller SRCS28X with on-board battery LSIiBBU01.
RAID controller firmware version - 815E.
Battery is bad after 1year.
I buy new battery LSIiBBU01 (LiON) and replace old battery.I boot system.
During this time, I see bios of controller don't loading and raid controller don't present in system after reboot.
I remove battery from controller and boot system without battery. Bios of controller upload and RAID controller present in system normally.
With new battery on board - controller don't defined in system.
Battery is good, I testing it with different RAID Controller (LSI SAS 8308ELP).
What can I do for installing new battery on RAID Controller SRCS28X ?
Any reaction yet?
I'm having the same problem: BBU is useless, controller doesn't work with BBU. After removing the BBU controller works perfectly. I'm also using firmware 815E.
I just installed AXXRIBBU01 on a SRCS28X Controller.
As soon as the batterypack is installed the controller won't POST anymore so there is no more Raidcontroller seen by the BIOS.
When I remove the pack it works.
Raidcontroller Bios is 815E .. is this a known problem or just a defective BBU ?
Cheers
