Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Problemas na atualização de Driver de Interface Intel
O Samsung Update solicita a atualização do Driver de Interface Intel ME  versão 11.0.0.1173, mas quando eu inicio a instalação, aparece o aviso "não foi possivel conectar ao servidor. Verifique se há problemas na rede e tente novamente.".
Minha conexão a internet está normal.
Highlighted
Hello nataliapontess,
Thank you for posting on the Intel® communities.
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; there may be some errors on said translation.
The Intel® Management Engine Interface (MEI) is a layer within the motherboard BIOS that allows interaction between the operating system and the BIOS itself. All the updates provided for MEI are provided directly by the system manufacturer (OEM).
I am seeing that you are using a Samsung Update tool, based on this; you should check with Samsung* for further assistance with this problem.
Sebastian M
Intel Customer Support Technician
Highlighted
I hope the previous information was useful to you.
As mentioned, you should check with Samsung* for further support with the latest updates and the Update Tool they offer.
We will proceed to close this inquiry, if you have any additional questions, please submit a new thread as this one will no longer be monitored.
Sebastian M
