We are planning to install Windows server 2008 64-bit on our server. Below is the system information of
our server. Please confirm whether the current hardware(processor) will be able to support
windows server 2008 64-bit OS.
OS Name Microsoft(R) Windows(R) Server 2003, Standard Edition
Version 5.2.3790 Service Pack 2 Build 3790
Other OS Description R2
OS Manufacturer Microsoft Corporation
System Name XXXXXXXXXXXX
System Manufacturer HP
System Model ProLiant DL360 G5
System Type X86-based PC
Processor x86 Family 6 Model 15 Stepping 11 GenuineIntel ~3000 Mhz
BIOS Version/Date HP P58, 24/01/2008
OM
Provide the processor model number.
From the information you have provided, I would have to say NO, it will not support a 64-bit OS.
Doc
Hi Al Hill,
Thank you for your reply. The processor model is Intel(R) Xeon(R) CPU 5160@3.00GHzl. Could you please confirm if the processor model will support Windows server 2008 64-bit OS.
It is difficult to say. This is your processor:
https://ark.intel.com/products/27219/Intel-Xeon-Processor-5160-4M-Cache-3_00-GHz-1333-MHz-FSB Intel® Xeon® Processor 5160 (4M Cache, 3.00 GHz, 1333 MHz FSB) Product Specifications
It supports 64-bit instruction set. BUT - is is very old and no longer supported.
Personally, I would upgrade your hardware to something MUCH more current.
Also, I will move this thread to the server forum, where you can get a better answer.
Doc
Hi Al Hill,
Thank you so much for your reply.
We have some challenges to upgrade to new hardware. Since you mentioned the current processor supports 64-bit OS, Will we be able to install Windows server 2008 64-bit OS on the server? We use this server for backup application to run(taking backups of client servers) and would be busy for around 12 hours a day. Please let us know, if we go with the current hardware, will we be facing any challenges or any performance issues?
Actually, I said it supports the 64-bit instruction set. It seems to have only a 32-bit address space, which means no matter what OS, you will be limited to 4gb.
So, you will need to wait until one of the Intel support staff look at this issue for an answer.
Doc
