Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4507 Discussions
Questions about Intel Server Board S1200KPR
RKoch1
Hi
I have some questions about the Intel Server Board S1200KPR and i hope somebody can help me.
I build a new Homeserver with the following components
- Intel E3-1265Lv2
- Intel S1200KPR
- OS: Windows Hyper-V 2012 Core
I would like to create RAID Arrays for my data. One RAID1 Array and One RAID5 Array.
1. In the Download section for this board is a donwload called "Intel RAID Web Console 2". This is the same Software which is use with Intel RAID Controllers. Can i use this Software to connect remotely to the OnBoard RAID Controller or is it only for use with Intel RAID Controller in PCIe Slots?
2. Can i use a Intel RAID Controller (for example RT3WB080) designed for Intel Xeon E5 Prosessors with this board? I cannot find any Informations if this combinations is compatible.
3. Anyone use this board with a RAID Controller? Which one?
Kind regards
Keks22
SMSchulz
I built one with RS2BL040 a while back.
It runs great.
I am not sure about the remote connection ~ I use the remote desktop connection then connect to the web console.
It is a client computer running Server 2012 std.
Daniel_O_Intel
The board uses Intel® Rapid Storage Technology, so RAID Web Console won't connect to it. The driver at https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22036 Download Center does include an Intel(R) Rapid Storage Technology application, though.
I don't see any list of tested hardware posted on the support site, though.
SMSchulz
It runs great.
