I was wondering whether Quicksync is compatible with Windows Home Server 2011?
I have an Asus P8H77-I, Intel 3450 CPU, 4Gb ram but I can not activate hardware acceleration in WHS2011. I have all the latest drivers installed.
If I use the exact same hardware and install Windows7 or Windows8 with latest drivers, then quicksync works fine.
Is there an issue with Quicksync and WHS2011 or is there a work around to get it working?
Thanks for your help.
If you don't get much response in the Server group, try the Graphics group over at
