Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4445 Discussions
R1000SPO (R1308SPOSHORR) cold swap internal SSD power cable
GRIFFCOMM
Hi all
I did have a similar question about this about 6 months ago, however i now have images and i believe part numbers.... the below image is one of the boxes in the above R1000SPO server barebones, in it are 2 small blue brackets that hold cold swap SSD in place (above the 4 hot swap 3.5inch bays). Also a power cable for these SSD drives.
2 images below:
RED = SSD cold swap SSD brackets (we believe part number : H95537-001)
ORANGE = SSD power cable (we believe part number : SSD PWR(PSU/SSD) H85969-002 AST1639)
Questions:
- I assume the PSU cable plugs in to the backplane (somewhere)
- How do we order these parts? (we need 4 of each (8 x brackets (there packs of 2) and 4 x power cables)
GRIFFCOMM
UPDATE
The back plane is a 4 pin connector, the connector from the PSU is 6 pin, the back plane only needs 12V (yellow and black) (documented in Intels PDF for that server chassis, see below, however can no longer be found on Intels servers!), the 2 extra pins are red (5v) and orange (3.3v) both needed for the SATA SSD drives.
So the above listed cable is a pass through cable, connects to the PSU power and passes to the back plane, if its not used the back plane will take the pin connector and only mate with 4 pins (from diagrams i have looked at).
Back plane power reference (document now cant be found but was on the below location)
Page 42
http://www.intel.com/content/dam/support/us/en/documents/server-products/Intel_Server_System_R1000SP... http://www.intel.com/content/dam/support/us/en/documents/server-products/Intel_Server_System_R1000SP...
This proves the chassis R1304SPOSHORR uas 4 x hotswap and 2 x cold swap drives:
Page 7
https://www.intel.com/content/dam/support/us/en/documents/server-products/S1200SP_P4000S_R1000SPO_Fa... https://www.intel.com/content/dam/support/us/en/documents/server-products/S1200SP_P4000S_R1000SPO_Fa...
Would this cable and plastic clips be part of the Intel FR1304E3V5ESK
https://ark.intel.com/products/88268/Electrical-Spares-Kit-FR1304E3V5ESK Electrical Spares Kit FR1304E3V5ESK Product Specifications
