Server Products
4867 Discussions
R1208SPOSHOR systems won't boot. They get to 4Fh and hang. Any suggestions?
GJohn1
We're using the E3-1275v5 processor with Kingston 8GB DDR4 DIMMs. The Kingston pn is KVR21E15D8/8. I have checked the jumpers and cables and those look O.K. I took the DIMMs out and then the system responds with 3 long beeps that says I have a memory error. So that part works and it appears the processor is alive. I checked the diagnostic LEDs. If I am reading them correctly, it appears the system stops on 4Fh. Also, the blinking LED next to the 8 diagnostic LEDs goes from blinking green to a solid amber. Then after a short time the machine reboots.
We can confirm that the memory part number you are using is not validated for the board reason why we recommend testing with the following part numbers instead to narrow the issue:
