Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
4732 Discussions
R1304BTL ME update failed?
Hello!
Recently I bought R1304BTLSHBNR server system and one of the first deployment tasks was to update firmware to latest. While updating ME part, error appeared on screen stating of "bios write error" and "installation successful". When viewing system information in BIOS, ME version now is "Read error".
I've checked the ME version in BIOS before updating - it was correct previous version. I've tried to re-update full firmware package and only ME part - same result with "read error".
While I have found, that in some manuals failure of ME is stated as critical failure with halted system, everything seems to function normal (working OS xubuntu, fans slowing down with updated FRUSDR, no visible error codes). Update instructions, manuals and internet do not review this issue.
1. How can I update the ME firmware? Or how can I see updated firmware version in BIOS?
2. Can I use current latest BIOS 1.14 and older ME firmware 1.13? Have not tried to downgrade to previous or older.
3. Does this "read error" means failed ME and how failed ME can affect server performance?
Thank you,
Sandis Krutovs
Nobody? Or is my question too boring?
Edward_Z_Intel
There is a ME Force Update Jumper on the board you may want to try. See the board http://www.intel.com/support/motherboards/server/sb/CS-032382.htm Technical Product Specification section 8.3 for details.
Thanks, Edward!
Just to be clear, 8.3 states I should set Integrated BMC Force Update jumper (logically, J4A2), not ME Force Update jumper (Figure 46. : J1F1). Copy-paste error or really BMC jumper?
Edward_Z_Intel
Hmmmm... I believe it should be the Me Force Update jumper (J1F2).
