Server Products
4784 Discussions
R1304BTLSHBNR Windows SBS 2008 R2 UEFI 1st boot failure after install on ESRT2 RAID10
I do have that R1304BTLSHBNR server with 4 x 2TB constellation drives in it. In BIOS the RAID option is set to ESRT2 (*LSI). I do have additional USB DVD drive to boot the Windows 2008R2 (actually Windows Small Business Server 2011 Essentials, but that is 2008 R2). Whatever I do, I can't run the Windows 2008R2 on a GPT RAID volume.
My installation procedure is as follows:
1. I set the first boot device UEFI USB DVD ( BIOS USB is deleted from the list just to be sure)
2. Boot from that option
3. Windows instaler starts
4. Load driver for ESRT2 -
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19991&lang=eng Download Center
(I have also tried http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20963&lang=eng Download Center, they work, but with the same effect - no system boot after install is finished).
5. Disk is recognized - 3,7 TB (so RAID 10 from four 2TB drives). I press Shift + F10, run diskpart to confirm that the drive is GPT - I see asterix in the GPT so the drive is in GPT partitioning scheme. I create no partitions.
6. I install Windows Server 2008 R2
7. After unpacking of files and 1st stage of my installation is complete, the 1st reboot comes.
8. System boots, I do not press a key to boot from DVD/CD.... and I end up with a black screen and a white "_" in the left corner of my screen.
If I change the boot order and move the "windows boot manager" after "Intel Embedded AHCI RAID", the system boots, installation might be completed, but I end up in the BIOS booting type and MBR drive. I do not know when and how this is changed.
If I try to modify the installation procedure with an added SATA DVD or from EFI shell, I end up with the same problem. What am I doing wrong?
I can switch to Intel RST, divide my RAID10 into two seprated VDs ( ESRT2 has only option for a single VD), then my first VD will be MBR (lets say 150GB) and the second one will be GPT (rest of the 3,7TB space)... but I thought that newer ESRT2 is better as well as the single VD with GPT scheme.
I could not find any threads or information about problems on ESRT2 UEFI/GPT installation.
Anyone willing to help ?
Edward_Z_Intel
Unfortunately UEFI installation is not supported on ESRT2. And ESRT2 only support one VD on RAID 10, so seems it's a deadend.
The workaround is to either switch to RST, or select a different RIAD level (RAID 1 or 5) which supports multiple VDs.
I did some comparison and it comes out that ERST-2 is much worse than Intel RST when it comes to RAID10 performance..... about three times for burst transfers 87MB/s vs 237 MB/s on Intel RST. Altough I feel defeated by not beeing able to do what I wanted to, eventually I ended up with a better solution.
Edward_Z_Intel
Just curious, how did you test the performance?
I have used HD Tune and Anvil. It is kind of pity that I did not save ESRT-2 results. I can still re-do and save the ones for Intel RST.
Of course testing the drive/array with the OS installed and running on it will never give accurate results, but you can get the basic camparison.
Additional interesting thing that I did not mention is that minimal transfer speeds were worse for Intel RST, even as low as 18 MB/s.
Edward_Z_Intel
I have a similar problem, but with Linux. I have got a workaround.
This may be very unviable in Server environments, but works: Use an USB drive to store the bootloader.
In almost any linux distribution, you can store grub and the /boot/efi folder wherever you want, including USB drives.
On Windows, you can try this: http://www.wintobootic.com/ WiNToBootic - the ultimate Windows 7/8 USB Boot Disk Maker
I use USB sticks for ESXi 5 hypervisors boot having a cloned backup unit near the server. It is not unviable. It might be a little bit problematic, that's all.
Thanks for your reply.
Wait... Are you using ESXi with E-SRT2?
