Server Products
Data Center Products including boards, integrated systems, RAID Storage, and Intel® Xeon® Processors
5073 Discussions
R1304RPMSHOR fans perpetually at 100%?
TBren1
We just bought a R1304RPMSHOR and for some reason the fans are at full speed at all times.
I have upgraded the BIOS to R01.04.0002, which did not help.
I have adjusted bios settings to acoustic and set altitude for <300m
I have checked http://www.intel.com/support/motherboards/server/sb/CS-022809.htm Server Products — System fan runs too fast or too loud and haven't gotten any results. Although i am unsure if I did the last one correctly.
Please help, the machine is so loud that we are disturbed by it, in spite of being behind a closed door.
Any help would be much appreciated.
TBren1
As always, once you finally get so far that you are ready to ask a question, you end up solving it by yourself.
I solved it by running the frusdr -cfg master.cfg, that came together with the R01.04.0002 firmware.
boot into efi
select yes to update both fru and sdr
then winged it through the rest of the questions.
TBren1
boot into efi
