Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4653 Discussions
R2208GZ4GC with A2U44X25NVMEDK NVME upgrade kit only 1 nvme detected
we have upgraded one of our R2208's with the NVME upgrade kit. Replaced Riser nr.2 with the included riser (2 slots) and used the (top) 16x slot for the nvme interface card.
However we see only 1 out of 4 NVME's. The first one on the left is active (green LED), the other 3 show no led activity at all, not physically and not in bios/windows.
Additional power connecter is connected. We are using Intel P3520. Any idea what can cause only 1 out of 4 drives being detected? Mainboard Bios is current.
Could this be a lanes issue? As the server has all other slots full.
Hello Guidom
Could you please provide us with more information about the specific hardware you have?
This could be a lanes issue as you mentioned.
If possible please provide us with the Syslog you could get it by using https://downloadcenter.intel.com/download/25440/Intel-System-Event-Log-SEL-Viewer-Utility-for-S1200-S1400-S1600-S2400-S2600-S4600?product=88288 Download Intel® System Event Log (SEL) Viewer Utility for S1200, S1400, S1600, S2400, S2600, S4600 .
Caesar B
Hi, after doing some more research it seems like there is a bios limitation in the GZ(v2) mainboards. There is no option to set PCIe port bifurcation this only seems to be possible in the newer WT(v3) models, so sadly it seems our servers cannot be upgraded currently
