Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4510 Discussions
R2208WFTZS loud after upgrade to BIOS: 00.01.0014
KubaW
Hello!
On new R2208WFTZS server upgraded firmware package from stock 00.01.0009 to 00.01.0014 and now fans are on 7000RPM all the time.
All fan are working and I do not see any errors. See attached Sysinfo logs.
Does any one of you have idea how to solve this issue?
Kuba W.
Hello KubaW,
Can you confirm which of the fans are the ones at full speed is that the PSU fans or the server board fans?
Charlie_Intel
KubaW
Hello Charlie!
System fans runs at speed >7000RPM:
Healthy Name Status Reading
OK System Fan 1 Normal 7367 R.P.M
OK System Fan 2 Normal 7367 R.P.M
OK System Fan 3 Normal 7367 R.P.M
OK System Fan 4 Normal 7314 R.P.M
OK System Fan 5 Normal 7367 R.P.M
OK System Fan 6 Normal 7367 R.P.M
I'm don't know where to check PSU fans speed.
Kuba W.
Hello KubaW,
Does the chassis has an intrusion switch? if it does please check that the door is closed.
Please check that all the fans are correctly seated.
Then try to re-run the latest BIOS update.
Please let us know how it goes.
Charlie_Intel
KubaW
There is no intrusion switch. Checked all 6 fans connection and there correctly seated.
Have you checked Sysinfo logs that I attached? Both intrusion and fan error should be reported there.
Tried re-flashing again BMC, BIOS and FRUSDR, but it didn't solve the issue.
Kuba W.
Hello KubaW,
We are going to have to play around with the server as it could be one or more issues.
First of all, are you using UPS? if you do, please try to connect the server directly to the wall outlet for testing purposes.
If the issue continues try just one memory per processor, clear the SEL and reinstall the BIOS update using EFI.
Charlie_Intel
KubaW
Hello Charlie and thank you for assistance!
I followed yours recommendations:
- connected server directly to wall outlet,
- removed all but one DIMM,
- cleared SEL,
- reinstalled BIOS using EFI.
Unfortunately it didn't helped.
I had no fan issues on stock firmware 00.01.0009. Is it ok to downgrade from 00.01.0014 to 00.01.0009?
Kuba W.
Hello KubaW,
You can perform the downgrade but I can not assure that it is going to work as when you change the firmware some data information from the chassis get lost so, this is what we assume that happened but let me double check the sysinfo and all the information and I will get back to you as soon as possible.
Charlie_Intel
KubaW
Hello Charlie,
Downgraded BMC and FRUSDR to version 1.43 (from 00.01.0013 firmware package) and left BIOS on version 00.01.0014. Server is now quiet and system fans are on 4000 R.P.M..
Do you need Systeminfo logs from current config?
Kuba W.
Hello KubaW,
If it is possible to share it with us so we can compare it that would be very helpful.
Charlie_Intel
KubaW
Hello Charlie,
I attached sysinfo logs from R2208WFTZS with BIOS 00.01.0014 and downgraded BMC/FRUSDR 1.43.
I can see some additional sensor readings on BMC 1.60 like "P1 Temperature" and "P2 Temperature" that are not present on version 1.43.
Kuba W.
Hello KubaW,
Thank you for the information, we are going to check on the files in order to see what is happening with the firmware update.
Charlie_Intel
Hello KubaW,
We are going to perform a lab for this thread and we will let you know the results as soon as possible.
Charlie_Intel
Hello KubaW,
Can you share status LED in the front of the chassis or back of the board is solid green or any other state?
Regards.
Charlie_Intel
KubaW
Hello Charlie,
It was green (not sure if solid) on BIOS: 00.01.0014 with loud fans.
On BIOS 00.01.0013 it is solid green and quiet.
Kuba W.
Hello KubaW,
Thank you for the information.
We are still working on it we will get back to you as soon as possible.
Charlie_Intel
SOber1
Hi, i have exactly the same problem after upgrading to "14". I've searched forever to find this post and am rather annoyed as you had several issues with sensors for YEARS. Is there any update when a "15" or never Version is coming? Otherwise i will downgrade my system beacuse with 53CFM and 7100rpm i can not deliver this system to my customer, that is just ridiculous .
BBopp
We got the R1208WFTYS Server wich I think has the same Mainboard S2600WFT. Same problem here after updating to 00.01.0014.
Hello KubaW, enox2, betterbits,
We apologize for the delay, we are still working in the case and researching the issue please be patience and we will get back to you as soon as possible.
Charlie_Intel
SOber1
I downgraded to the 13-Package and the Bios stayed on .14. So it's either in the BMC-Code or the ME-Code or the SDR. The downgraded version of mine looks like this:
BIOS ID :SE5C620.86B.00.01.0014.070920180847BMC FW Rev :1.43.91f76955Backup BMC FW Rev :1.60.56383befBuild ID :91F76955SDR Package Version :1.43Mgmt Engine (ME) FW Rev :04.00.04.294
OKSystem AirflowNormal
25 C.F.M
OKSystem Fan 1Normal3392 R.P.MOKSystem Fan 2Normal3445 R.P.MOKSystem Fan 3Normal3392 R.P.MOKSystem Fan 4Normal3392 R.P.MOKSystem Fan 5Normal3392 R.P.MOK<td style="border-bottom: 1px solid # cccccc; backgr...
BBopp
Do you guys also have the problem that some sensors are showing minus degrees? Like DIMM Thrm Mrgn 1 -39 degrees in the sensor reading?
