Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
R2308IP4LHPC fans run at maximum speed, regardless of Acoustic/Performance settings
Jump to solution
I recently purchased an old R2308IP4LHPC 2U server. Unfortunately, it sounds like a jet engine all the time. I changed the bios settings to auto throttling, acoustic profile, and quite fan idle mode enabled in the System Acoustic and Performance Configuration menu, yet nothing changes. I have noticed that the processor clock speed is not being throttled (i.e., each cpu core is at stock frequency) yet the cpu utilization is reported at less than 5%, so it's definitely idling.
Any suggestions how to get the fan speeds to manager correctly?
Accepted Solutions
Highlighted
Community Manager
Re: R2308IP4LHPC fans run at maximum speed, regardless of Acoustic/Performance settings
Jump to solution
As the first recommendation please use the https://www.intel.com/content/dam/support/us/en/multimedia/5890_serv_loud_fan_ts/index.html troubleshooting wizard for resolving high fan noise issues.
You can also download and perform a BIOS recovery for your server board, you can download the latest version https://downloadcenter.intel.com/download/26956/Intel-Server-Board-S2600IP-and-Intel-Workstation-Boa... here. You can find instructions https://downloadmirror.intel.com/26956/eng/ReleaseNotes_BIOS_02.06.0006.txt here.
I hope this helps.
Sergio S.
Highlighted
Community Manager
Jump to solution
I hope this helps.
Sergio S.
Highlighted
Jump to solution
Highlighted
Community Manager
Jump to solution
Hello Joseph,
I am glad to hear that I was able to assist you with your problem, please let me know if there is anything else we can do for you.
Sergio S.
Highlighted
Community Manager
Jump to solution
Hello Joseph,
I am following up your question, in case you need further assistance please feel free to contact us back.
Regards.
