Server Products
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
4732 Discussions
R2308WTTY not starting
MGera1
I have a problem with the new server platform R2308WTTY. After power on i dont get any video, all the fans run at maximum speed
Specs:
Server platform R2308WTTY
MB S2600WT
2 x XEON E5-2630 v4
8 x KVR24E17D8/16
Error
POST error code 3 beeps
green:
0=on
1=on
2=on
3=off
orange
4=off
5=off
6=off
7=off
Can you help me?
Hello Mikhail,
The 3 beeps during the system post indicate that there is a memory error, you can find more information https://www.intel.com/content/www/us/en/support/articles/000006001/server-products.html here.
As the first troubleshooting step, we recommend using https://serverconfigurator.intel.com/exalt/RequestManager?ServletNumber=1&dynamicUser=Y&localinfo=0&RestrictionVal=SVG&APPLICATIONCODE=1 tested memory on your system.
You can also try to test your system with the minimal system configuration ( processor, server board, one memory stick) and check if the problem continues.
Also, try testing each memory slot at the time.
Sergio S.
Hello Mikhail,
Sergio S.
MGera1
Hello Sergio, thanks for answer.
I think that the problem is in an unsupported memory type. We try to use UDIMM memory, but in MB specs and E5 Xeon 2630 v4 only RDIMM or LRDIMM.
Can you confirm that?
Hello Mikhail,
Upon checking the list of tested memory for your device, most of the memory supported is RDIMM, you can confirm this information here:
Sergio S.
Hello Mikhail,
We are following up your question and we would like to know if you need further assistance.
Sergio S.
I case you need further assistance please contact us back.
Sergio S.
