Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4661 Discussions
RAID 1 COM HDS E SSD
dferr5
Estou tendo problemas ao configurar RAID 1 (discos magnéticos) com adição de um SSD (sem que este faça parte do raid). Terá uma outra função dentro do SO.
O SSD é reconhecido na BIOS, no entanto, quando o SO (Win2008R2) sobe o SSD não fica disponível para configuração.
Preciso de ajuda para solucionar este problema.
Minha placa é uma S3420GLP
Hello Demetrio,
Can you please let us know what RAID solution you are using?
If you are using the ESRT2, you will need to configure the single drive as a single RAID 0 drive.
You can find additional information https://www.intel.com/content/www/us/en/support/articles/000007554/server-products.html here.
Once it is created you would need to make sure to partition the drive and assign a letter.
If you are using the RST, which should be plug-in-play, you just need to make sure the drive is formatted
Sergio S.
Hello Demetro,
I am following up your question, please let us know if you need further assistance.
Sergio S.
dferr5
Morning,
I will follow yours orientations and will post here the results. Ok?
Hello Demetrio,
No problem, we will look forward to your response.
Sergio S.
Hello Demetrio,
We are following up your case, in case you need further assistance please contact us back
Sergio S.
