The pc is freezing at Copying Windows files (0%)...
I followed this document by intel.
GUID Partition Table (GPT) How to install an Operating System (OS) using the
GUID Disk Partition Table (GPT) on an Intel® Hardware RAID (HWR) Array under
uEFI environment.
CPU Xeon E5606 x2
memory DDR3 32GB
MB S5520HC
RAID card RS2WC080
all firmware updated.
Build RAID 5, total space 2.7TB.
Need install windows server 2008 R2 x64 Std.
Could you help?
Thank
Is this the document you're using?
http://www.intel.com/support/motherboards/server/sb/CS-031158.htm Using GPT (GUID Partition Table) with Intel� RAID Controllers
Were you able to see the correct drive size when partitioning the HDD? Was "EFI Optimized Boot" enabled in BIOS? Did you run BOOTX64.EFI under EFI shell to start the installation?
Thank you answer.
YES. I used this. http://www.intel.com/support/motherboards/server/sb/CS-031158.htm Using GPT (GUID Partition Table) with Intel� RAID Controllers
All step followed.
I see the driver is correct size. 2.7TB.
First time, I choose total to install.
Second time, I choose to make 3 partitions, 200G, 500G, 2000G.
All same issue. The server is freezing at Copying Windows files (0%)...
"EFI Optimized Boot" enabled in BIOS.
Run BOOTX64.EFI under EFI shell to start the installation.
Could you help?
I don't know why it's freezing, but if you need a quick fix, create a small VD less than 2TB for OS installation, and create a second VD for data storage. The data VD can be larger than 2TB. Disable EFI Optinized Boot and boot from DVD normally to install OS.
