Good afternoon Dear experts!
I had the following problem, and I can not figure out what it is related to.
I use the S5500BC motherboard, to which the RAID controller RS2BL080 is connected in the quantity of 1 pc.
This RAID controller worked on SATA HDD in the amount of 6 pcs.
After 1200 days of HDD operation, the OS with RAID ceased to run.
I checked the SATA HDD and they are all working.
I created a new RAID configuration of 1 or 0.
After that I succeeded, where it is written that VD0 is created and online.
After that, I'm trying to install Windows 2008 R2, but the initial level is loading from the installation disk, and then drastically goes into reboot.
What is the reason for this?
The BIOS has RAID boot enabled.
Can you help with this issue?
- Tags:
- RAID
Topic Options
