I am using an RS2BL080 RAID controller in an SR2600UR server system. My question is, should I be using an HBA cable to connect the controller to the server midplane? I have several servers with this configuration, but only recently started using the HBA cable. I have new server, with the HBA cable connected, and it rebooted and generated this error:
Controller ID: 0 Sensor bad on enclosure: 1
Sensor 5
Event ID:184
Is the HBA cable necessary and could it have contributed to the error? Any help is appreciated.
diamondcomics,
Does the http://www.intel.com/support/motherboards/server/sb/CS-025358.htm Rack-optimized systems backplane and RAID Controller cabling guide help?
John
diamondcomics,
John
