Have Intel Server with S2600ip4LHPC mobo and RMS25CB040 controller.
Upon warm boot, no controller is discovered = no data drive.
Upon cold boot, controller is discovered = have my data drive.
No other issues, is only an issue each month following Windows updates.
BIOSID: SE5C600.86B.01.02.0009.042520121156
RMS25CB040 is 6.702.7.0
Not sure what changed...have not really done much with system since original deployment Q4-2012
Past several months have just been powering down and restarting as work around...
Could have been addition of drive that is on the internal RAID controller....as a non-member, non-RAID drive.
Integrated controller, using ESRT2, has 3 drives, 2 RAID-1, 1 non-RAID
External controller, RMS25CB040, has 4 drives RAID-10
POST never 'sees' the RAID card on restarts - takes a power cycle to discover the card.
We have had some issues with Windows Updates on 2003 servers, this is a 2012... but this is obviously pre-O/S.
Could be driver update distributed through Microsoft updates.
Just curious if anyone has ideas before I start throwing a lot at it...
It would be a good idea to capture the Intel System Information Retrieval Utility logs to learn what's being recorded when this issue occurs.
Additionally, I noticed that the BIOS version of the unit is a bit out of date. In order to update to the most recent version https://downloadcenter.intel.com/download/24614/Intel-Server-Board-S2600IP-and-Intel-Workstation-Boa... 02.04.0003 you need to update the BIOS to the https://downloadcenter.intel.com/download/21492/Intel-Server-Board-S2600IP-and-Intel-Workstation-Boa... 01.03.0002 first.
It was not noted in your comments but in case is needed the most recent firmware for the RAID controller is https://downloadcenter.intel.com/download/24834/ir3-2208-ROC-Hardware-RAID-Firmware-Flash-Update 23.33.0-0022.
Are there any other cards installed in the system?
Thanks for looking.
Yes, realized everything was older than I thought...have downloaded updates and will try to apply - soon - before next 'update Tuesday'...
With luck won't screw something else up...
