Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4778 Discussions
RAID controller 11th gen Intel I9-11900K 3,50GHz
LeRich
Hello.
I found a device warning that includes the code : Device PCI\VEN_8086&DEV_43DE&SUBSYS_B0051458&REV_11\3&11583659&0&B8 requires further installation.
and under that this one :
Device PCI\VEN_8086&DEV_43DE&SUBSYS_B0051458&REV_11\3&11583659&0&B8 was configured.
Driver Name: null
Class Guid: {00000000-0000-0000-0000-000000000000}
Driver Date:
Driver Version:
Driver Provider:
Driver Section:
Driver Rank: 0x0
Matching Device Id:
Outranked Drivers:
Device Updated: false
Parent Device: ACPI\PNP0A08\0
Can someone please help , thank you
JosueO_Intel
Hello LeRich,
Thank you for posting on the Intel communities. In order to have a better understanding of the issue, please share with us the following information:
  1. When did the issue start happening?
  2. Is this a desktop or a laptop?
  3. Where are you looking at the issue? Please provide us a screenshot
  4. The version of both Intel® Rapid Storage Technology (RST) and Intel® Optane™ Memory and Storage Management.
Also, please download and install the Intel System Support Utility (Intel SSU):
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View".
Click on "Next", save the report and attach it to your response.
Josue O.
JosueO_Intel
Hello LeRich,
Josue O.
JosueO_Intel
Hello LeRich,
Josue O.
