Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4657 Discussions
RAID firmware update hosed the controller
I have an Intel S5520HC motherboard in a server and I was doing an update of the RAID firmware from the website. I logged into the Intel support website and downloaded the file (EPSD_SAS_FW_v.2012.06.29_ph20upd.zip) that was listed on the website as the firmware update file for this motherboard. I then unzipped the file to a USB thumb drive and rebooted the server into the EFI shell according to the instructions. I then proceeded to launch the AXX4SASMOD.nsh script which was listed on the instructions as the one pertaining to my motherboard. After erasing the flash on the controller, it gave two error messages that matched those on the readme as known errors that could be ignored. After completing the update, it said the update was successful, however it also gave the following:
LSI Corporation SAS FLASH Utility.
SASFlash Version 1.20.00.01 (2011.03.28)
Advanced Mode Set
Adapter Selected is a LSI SAS 1068E(B3)
Controller is not operational. A firmware download is required.
Enter firmware file name or quit to exit.
I have no clue what firmware file name to put in here. If I reboot the server, the RAID controller is completely missing. I need some quick help to recover this RAID controller. Thanks for any help you can provide.
I have one thing to add to the mix. In the flash process, I encountered the following error:
ERROR: NVSRAM ir required to flash IR firmware!
I thought this may be relevant. Thanks again for your assistance.
One other tidbit. The BIOS on the motherboard is S5500.86B.01.00.0061 dated 3/9/12
