Server Products
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
4732 Discussions
RAID0 with the Operating system W2012R2 on breaked apart.
SChe
My RAID0 with the Operating system W2012R2 on breaked apart. Intel Storage Utility shows status "Rebuild" and it will be rebuild whithin operating system, but I can't starst the operating system. Pls, tell my how to rebuild that RAID. Urgent situation!
Salem_W_Intel1
If by "breaked apart" and "Intel Storage Utility", you refer to a failed drive and Intel(R) Rapid Storage Technology enterprise [Intel(R) RSTe], since it is a RAID 0 array, there is no rebuilding taking place because "no redundancy information is stored in a RAID 0 volume" (qtd. http://www.intel.com/support/chipsets/imsm/sb/CS-009337.htm# raid0 here). If your Operating System, therefore, was on this RAID volume in question, I confirm it will not boot right back. "When a RAID 0 volume fails or is disconnected, the data on the hard drive is no longer accessible" (qtd. http://www.intel.com/support/chipsets/imsm/sb/CS-020992.htm?wapkw=raid+0 here). For more details, you can find the Intel® RST User Guide at the following URL:
http://www.intel.com/support/chipsets/imsm/sb/CS-020670.htm Intel® Rapid Storage Technology (Intel® RST) — User Guides
SChe
Sorry I made a mistake, I was talkink adout Raid1, not Raid0.
David_A_Intel
What is the model of the system board you are using?
You can always start the rebuild process within the RAID BIOS (CTRL+I) but the rebuild takes places when the service is started at the Operating System level.
Were you able to access your Operating System before you started the rebuild?
