Hello , we recently boutgh SR2500ALLXR the server. Problem manifested
that our dealer supplieds us with RAID5 AXXRAK18E key only with out
memory MINI-DIMM AXXMINIDIMM module . Is AXXMINIDIMM module
requirment for RAID5 to function propelry on SR2500ALLXR?
The Error that we get is on start up of server LSI Logic controler error on adress 01DH.
- Tags:
- RAID
Yes, you need the DIMM too. See the config guide at http://www.intel.com/support/motherboards/server/s5000pal/sb/CS-022659.htm
