Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4784 Discussions
RAM Detection IN Intel S5000VSA
Total 4GB RAM installed in the server but,
Available RAM is 2.49GB. Operating System is Windows Server 2003 R2 Standard Edition Service Pack 2.
Board: Intel S5000VSA
Serial Number: QSSA82800020
Bus Clock: 1333 megahertz
BIOS: Intel Corporation S5000.86B.10.00.0088.031420081550 03/14/2008
Memory Modules c,d
2554 Megabytes Usable Installed Memory
Slot 'ONBOARD DIMM_A1' has 2048 MB (serial number 5340E808) Slot 'ONBOARD DIMM_A2' is Empty
Slot 'ONBOARD DIMM_A3' is Empty
Slot 'ONBOARD DIMM_A4' is Empty
Slot 'ONBOARD DIMM_B1' has 2048 MB (serial number 5340E810) Slot 'ONBOARD DIMM_B2' is Empty Slot 'ONBOARD DIMM_B3' is Empty Slot 'ONBOARD DIMM_B4' is Empty
Edward_Z_Intel
This is the limitation of IA-32 architecture and 32-bit OS - the total addressable memory is 4GB, and certain memory range below 4GB is reserved for BIOS, PCI-E device, VGA, etc. See http://www.intel.com/support/motherboards/server/sb/CS-010458.htm http://www.intel.com/support/motherboards/server/sb/CS-010458.htm.
64-bit operating system can use memory above 4GB. If you have to use 32-but OS, try the following BIOS setting to get more usable memory:
Advanced => PCI Configuration => Memory Mapped I/O Start Address => 3.5GB
Note: If any device is not working properly after you choose 3.5GB, try 3.25GB, 3.0GB and 2.75GB in order until all devices are working properly.
