Good Friday everyone,
I am setting up an Intel S2600STBR with dual Silver 4116 Xeons. I have some PC4-2133P RAM, will I be taking a performance hit instead of using PC4-2400 or PC4-2666?
Ray
Hello RSump1,
Thank you for joining the Intel community
According to the Technical Product Specification document for the S2600STB board family, you should be able to install memory up to 2400 MT/s when using Xeon Silver processors. So, to answer your question, if you plan to use PC4-2133P RAM if shouldn't create such a dramatic performance difference. Probably you should be able to somehow compensate with a larger amount our RAM.
Hope it helps
Jose A.
For firmware updates and troubleshooting tips, visit:
https://intel.com/support/serverbios
I will assume using PC4-2666 will be fine too, the silver processor is capped at 2400.
Ray
Hello RSump1,
It should yes. In such case the bottleneck will be created by the CPU and not the RAM.
Jose A.
Hello RSump1,
I am just following up to double-check if you found the provided information useful. If you have further questions please don't hesitate to ask. If you consider the issue to be completed please let us know so we can proceed to mark this thread as closed. I will try to reach you as a very last time on next Monday 27th. After that the thread will be automatically archived.
Jose A.
Hello RSump1,
We will proceed to archive this thread. If you have further issues or questions just go ahead and submit a new topic.
Jose A.
