After logging in to RMM3 web gui I clicked "Sensors" without any response and I cannot login now, it refuses any connection (HTTP 111 Connection refused)
I have a S5500BC board with one Xeon and 12GB of Kingston ECC RAM. It happened while testing the server but I didnt find the cause, the only solution was to power cycle the PSU of the server (complete shutdown). Now its running a webserver with hundreds of webpages and I am not able to reset the whole server now because it is in the server house
Which BMC/RMM firmware version are you using? Have you tried to update to http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17905&ProdId=3076&lang=eng latest firmware package?
I am not able to find out RMM FW version as I can't connect to it, everything else is up to date, I updated everything (except RMM3, because I did't find any update) before I put the machine into the server house.
Was the RMM3 installed when you updated everything else? (to which version?)
RMM3 code is updated along with the BMC code during the BMC update. If the RMM3 was not installed when the BMC was updated, they are likly running differewnt code levels which could be your problem
sorry for reopening such an old topic, but I finally got server to my office, did a latest FW update (with rmm3 inside) and everthing is OK now, probably code incompatibility caused by the first update.
thank you.
