Server Products
Data Center Products including boards, integrated systems, RAID Storage, and Intel® Xeon® Processors
5022 Discussions
RMM3 + add-in video card
My question is that whether the RMM3 module is capable to pass the video of an add-in video card through KVM-over-IP, or it only can pass the video of the controller that is integrated in the board's BMC?
I've just installed a video card into my S3420GPLX, the result is 'No Signal' on the remote side.
Thank you and regards,
Janos
Edward_Z_Intel
No RMM3 does NOT work with add-in video card.
It's sad but understandable.
I have to look for another solution because the integrated Matrox G200 is weak to me.
Thank you for the quick reply, regards,
Janos
So what are the options? I have an s5520sc with only an internal video connection on the board.
Edward_Z_Intel
Consider SOL for pre-OS boot and software-based KVM within OS.
Sorry, but what is sol? I was told by tech support it will work as long as the cable for internal vga on mboard is present as primary video and external vga as secondary it will work.
Edward_Z_Intel
Yes that will work but with limitation in Windows - the onboard video doesn't have WDDM driver but only XPDM driver, which means if you want to use both in Windows you'll have to use XPDM driver for add-on video too.
SOL = Serial Over LAN. It's text based console redirection for pre-OS remote management.
i have both videos using basic vgapnp driver, but added video card returns status 10. What am I doing incorrectly?
...i am looking for even generic xpdm drivers on intel download (to which some threads have alluded to) but can find nothing. Can you provide an xpdm driver for both video cards?
Edward_Z_Intel
