Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
5016 Discussions
RMM4 on a S2600GZ board issue
SNaza1
Platform R1304GZ4GC, server board S2600GZ
BIOS 02.06.0005, BMC FW 01.27.9958
After trying logon with bad password using https BMC stop to respond to http, https and even telnet.
Only a complete power outage allows reconnect to RMM
This screen - login to RMM4 through separate RMM Lan or Lan1 with correct password
and this one - after first wrong password
Hello Sergey,
We can see that you were not able to connect to the RMM4 with a wrong password and then you tried in a different LAN with the correct one.
The full power cycle by unplugging the power cables and holding down the power button for 10 seconds will reset the BMC and will synchronize again with the RMM4.
After the full power cycle, can you try the correct password in the RMM4 to see if it does the same?
Bear in mind that the RMM4 IP address needs to be different that the BMC address just in case.
You can also try a different browser and see if the issue continues.
We can also see that there was a certificate error in the first screen shot. Please make sure that the date and time is set correctly in the computer you are using.
If by any chance you are still having issues, the next course of action will be updating the firmware again to the latest version.
Please let us know if you are still having issues after those steps.
Esteban V.
SNaza1
Hello Esteban
No. I try to connect to RMM always by one IP address, you can see it on screenshot - https://197.12.11.82.
When I use correct password, I repeately make logon-logoff. When I connect by http, after wrong password I see "Login failed. Please try again." When I connect by https with wrong password, immediately BMC stop to respond to any connections - http, https, telnet 80 port
Yes, after power cycle I can connect with correct password.
The issue is not depend on OS, browser and so on. I try Win7, 8, 10, Srv 2012R2, Srv 2016, Edge, IE 11, Chrome, Opera
If you look at the certificate, it is issued to AMI from ‎20 apr ‎2011 ‎г. 12:11:51 till ‎24 ‎march ‎2016 ‎г. 12:11:51
Firmware is already latest, and I update It several times
Unfortunately the problem is still not solved
I noticed this is happening when you are trying to connect to the RMM4 Web Interface. Does it happen the same with the Integrated BMC interface?
When this happens, are you still able to ping the RMM4?
I haven't seen this issue before. I am going to see if we could replicate it in our end. Have you tried to login from the actual server instead of using a client system?
Dave A.
SNaza1
The issue is replicated when connecting to BMC LAN1 and to RMM 4, and I still able to ping the system on both interfaces.
And I see issues like this before, for example - last message in this thread -
Thanks for the update. It seems more an issue with the BMC itself. At this point I would contact your nearest Intel office to follow up this situation.
Dave A.
