Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4612 Discussions
RS2BL080 Dual Linking and Cold Boot Wierdness
PWixn
Hello Community.
First post and two questions:
Does the RS2BL080 support Dual Link?
I have two SFF-8087 cables connected to a Dual Link-capable backplane-expander but the RWC2 states connection on port 0-3 only.
Does this scenarion require some extra software or hardware configuration?
During Cold Boot, my server gets stuck on "Initializing Devices"
This happens with both "certified" and "non-certified" drives. Soft rebooting by CTRL-ALT-DEL or by IPMI solves the issue and the controller detects all (both "certified" and "non-certified") devices.
Cheers
We can confirm that the RAID controller supports Port selector (for dual-port drives) but the hardware user guide does not mention anything about dual link support.
When the server gets stuck on "Initializing Devices" the reason could be a failing drive or the RAID Controller. Make sure you have the latest firmware and if the issue persists contact our support group directly for assistance:
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
PWixn
Hi and thank you for your reply,
I have already reflashed the latest firmware twice and none of the disk reports any physical or logical error (SMART, HDTune, CHKDSK)
If I recall this correctly, this mischievous error appeared on another set of mechanical drives on a firmware upgrade a couple of revisions ago. One day the "Initializing Devices" worked as intended but on the next cold boot, the boot process halted on "Initializing Devices"
