Hi, I bought a Raid Adapter RSP3TD160F and I tried to install it, but I got this message: "AVAGO MegaRAID SAS-MFI BIOS"
"Version 7.02.03.0 (Build May 24, 2017)"
"Copyright(c) 2017 AVAGO Technologies"
"No MegaRAID Adapter Instaled"
Please to see attached picture!
First, I installed on motherboard EPC602D8A (Asrock) on Debian 10 OS.
Second, on motherboard C266WS (Asrock) on Debian 10 OS.
Third, on motherboard H370M PRO4 (Asrock) on Windows 10 OS.
I got the same message 3 times: "No MegaRAID Adapter Instaled" .
Somebody can help me to fix the problem?
Thank you an advance!
This is not an Intel raid adapter and not an Intel server board. Have you contacted asrock and/or avago?
Doc
Hi, I'm pretty sure is a Intel Raid Adapter, just take a look of the below link
https://www.intel.com/content/www/us/en/products/servers/raid/raid-controllers/rsp3td160f.html
Thank you!
I added more picture with the part numbers of this Intel Raid Adapter.
Thank you!
So it is. One of the Intel support engineers will assist you.
Doc
Hello MFina1,
Thank you for contacting Intel Server Community Support.
I was reviewing the information provided and this is an Intel® RAID Adapter RSP3TD160F.
However, our Intel RAID adapters are meant to be mainly used in an Intel Server Board or Server System.
- Did you already confirm the compatibility of the RAID Controller with the Asrock Motherboards?
- Did you have the BIOS Version of the Asrock motherboards up to date?
- Did you already contact Asrock's support in order to verify this implementation?
- Have you used an Intel RAID Controller into these Asrock Motherboards previously?
I will be waiting for your outcome in order to proceed with the next step.
Emeth O.
Intel® Server Specialist
A Contingent Worker at Intel.
The Intel RAID Adapters will support Tri-mode PCIe/SAS/SATA.
Please let me know if you have more questions and I will be more than happy to assist.
Emeth O.
I am following up on your thread in order to verify if you have more questions or if there is something else I can help you with?
If so, please do not hesitate and let me know and I will be more than happy to assist you.
Emeth O.
I was reviewing your thread and I have not seen any activity recently.
If you have more questions, do not hesitate and contact us back and we will be more than happy to assist you.
Emeth O.
