Hello!
My Raidcontroller SRCSASRB died! It is the second controller in this server which says Memory Error!
I'm unable to source this controller so i would like to know if the array could be read/mounted with a SRCSATAWB!?
I hope someone can help me out!
Last time the controller died john_s@intel was very helpfull - but i dont know if he's still in the forum!?
Best regrads,
Florian
- Tags:
- Controllers
Hello Flop2,
I will like to apologize on the problems you have encountered with SRCSASRB.
First I just wanted to provide with some information on Intel Policies.
"Intel Customer Service no longer responds to telephone, chat, or e-mail inquiries for this SRCSASRB but you may want to try our /community/tech/discontinued-products Discontinued Products Community to get recommendations from fellow community members. You may also find the https://www.intel.com/content/www/us/en/support/discontinued-products.html Discontinued Products Website helpful to address your request".
With your question, that you would like to know if the array could be read/mounted with an SRCSATAWB!?
Verifying the specs on each of the two cards:
SRCSASRB
https://ark.intel.com/products/32254/Intel-RAID-Controller-SRCSASRB https://ark.intel.com/products/32254/Intel-RAID-Controller-SRCSASRB
SRCSATAWB
https://ark.intel.com/products/32256/Intel-RAID-Controller-SRCSATAWB https://ark.intel.com/products/32256/Intel-RAID-Controller-SRCSATAWB
They both use the same IO processor – LSI1078.
But the SRCSATAWB only manages SATA and the SRCSASRB will manage SAS/SATA.
And because the board is EOIS is limit the information we have on them.
If there is anything else we can help please feel free to ask.
Henry A.
Hello Flop2,
I will like to follow and verify if the informaiton provided helped to answer your question.
Henry A.
Hello Henry,
thx for your reply! In the meantime I can confirm...the srcsatawb CAN read the array of srcsasrb!
I made a new config via the wizard...connected the drives an all came out perfectly fine.
Best regards
Florian
Hello Flop2,
Thank you for the updated information and I very glad the data was access.
Henry A.
Hello Flop2,
We are following up on a case that is still open with the issue "you would like to know if the array could be read/mounted with an SRCSATAWB!", I just wanted to see if you have any additional information you might require help with.
Please just keep in mind that for Discontinued Products we have limited information.
The case will automatically close after 2 business days. You can still re-open the case by logging into your web portal or replying to this email so that all previous interactions around this case will carry through."
If you have any questions, please let me know.
Henry A.
