Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4784 Discussions
Rapid Storage Technology RAID 5 Initialization stopped at 69%
MFakl
Using version 12.5.0.1066 of RST running Windows Server 2012 Standard on a ASUS P6X58-E WS motherboard, which has an Intel ICH10R controller which supports Intel Matrix Storage Technology. I installed 6 identical new Seagate 2 tb drives (ST2000DM001). 5 disks are assigned to a RAID 5 array (using all of the storage), and the 6th drive is a hot spare. The RAID 5 volume is shown to be 7452 gb.
The RAID 5 initialization was moving along a an acceptable pace, but stalled at 69% (2 days ago). I've found no messages indicating any problems. Does anyone have any insights. Where should I look for error messages?
- Michael Faklis mailto:Michael_Faklis@EvolSwSys.net Michael_Faklis@EvolSwSys.net 415-772-1921.
DArce
Valued Contributor III
Could you please post the report generated by Intel(R) Rapid Storage Technology?
For information on how to get this report you can refer to this article:
http://www.intel.com/support/chipsets/imsm/sb/CS-023487.htm Intel(R) Rapid Storage Technology (Intel(R) RST) | System reports
MFakl
Forgive me for the delay, but I had to repeat the procedure (as I understand it) to make sure I had a repeatable problem description. The requested report is below:
I have 6 identical new disks (Seagate 2 tb ST2000DM001), initialized with CMD > DISKPART > CLEAN. I defined a RAID5 array using the 1st 5 disks, while intending to use the 6th disk as a hot spare after the initialization completes. After defining the RAID5 array, the RST screen tells me to define a partition and format it. I rebooted and then using the Windows Disk Management control panel, I defined a single simple volume using all available space (7451 gb), and formatted it as ReFS.
The RST status panel showed progress for 2 days and then stalled at 69%. The Computer Management panel showed progress during that period and stalled at 16% formatted.
I questioned (to myself) why I was being asked to partition and format the array so quickly, by RST showed the array was initialized almost immediately by the time I was asked to define and format my partitions.
System Report
System Information
OS name: Microsoft Windows Server 2012 Standard
OS version: 6.2.9200 9200
System name: ESSWS2012HV
System manufacturer: System manufacturer
System model: System Product Name
Processor: GenuineIntel Intel64 Family 6 Model 26 Stepping 5 2.673 GHz
BIOS: American Megatrends Inc., 0301
Intel® Rapid Storage Technology enterprise Information
User interface version: 12.5.0.1066
Language: English (United States)
RAID option ROM version: 8.0.0.1038
Driver version: 12.5.0.1066
ISDI version: 12.5.0.1066
Storage System Information
RAID Configuration
Array Name: SATA_Array_0000
Available space: 19 MB
Number of volumes: 1
Volume member: ESSWSHVR5
Number of array disks: 5
Array disk: Z1E36GQD
Array disk: S240LT98
Array disk: Z1E36HXP
Array disk: Z2F02X4S
Array disk: W1E0D8ES
Disk data cache: Enabled
Volume name: ESSWSHVR5
Status: Initializing 69% complete
Type: RAID 5
System volume: No
Data stripe size: 128 KB
Write-back cache: Off
Initialized: Yes
Parity errors: 0
Blocks with media errors: 0
Physical sector size: 4096 Bytes
Logical sector size: 512 Bytes
Hardware Information
Controller name: Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller
Type: SATA
Mode: RAID
Number of SATA ports: 6
Volume: ESSWSHVR5
Number of spares: 0
Number of available disks: 1
Rebuild on Hot Plug: Disabled
Manufacturer: 32902
Model number: 10274
Product revision: 0
Direct attached disk: Z1E36GQD
Direct attached disk: S240LT98
Direct attached disk: Z1E36HXP
Direct attached disk: Z2F02X4S
Direct attached disk: W1E0D8ES
Direct attached disk: S2F07SF5
Disk on Controller 0, Port 0
Status: Normal
Type: SATA disk
Location type: Internal
Usage: Array disk
System disk: No
Command queuing: NCQ
SATA transfer rate: 3 Gb/s
Model: ST2000DM001-1CH164
Serial number: Z1E36GQD
SCSI device ID: 0
Firmware: CC26
Disk on Controller 0, Port 1
Status: Normal
Type: SATA disk
Usage: Array disk
System disk: No
Model: ST2000DM001-9YN164
Serial number: S240LT98
SCSI device ID: 1
Firmware: CC4H
Disk on Controller 0, Port 2
Status: Normal
Type: SATA disk
Usage: Array disk
System disk: No
Serial number: Z1E36HXP
SCSI device ID: 2
Firmware: CC26
Disk on Controller 0, Port 3
Status: Normal
Type: SATA disk
Usage: Array disk
System disk: No
Serial number: Z2F02X4S
SCSI device ID: 3
Firmware: CC9C
Disk on Controller 0, Port 4
Status: Normal
Type: SATA disk
Usage: Array disk
System disk: No
Serial number: W1E0D8ES
SCSI device ID: 4
Firmware: CC4C
Disk on Controller 0, Port 5
Status: Normal
Type: SATA disk
Usage: Available
System disk: No
Serial number: S2F07SF5
SCSI device ID: 5
Firmware: CC4C
DArce
From what I see in the report your system is using an really old version of the Option ROM. You should check with Asus* for updated BIOS that should install an updated version of the Option ROM.
There is a method that you may follow to try to update this on your own, however this is not supported nor validated from our side. You may try it under your own convenience only if Asus* may not provide you an updated version. For more information you can use this as a reference:
MFakl
Problem Solved!
1st: I had to remove Intel's Matrix Support Technology. I had the most recent release, but little did I know upon the next release, Intel renamed the program to Rapid Storage Technology. I installed the latest release of RST.
2nd: When you define your raid array using RST, I gives you a message that you must define and format partition(s) before populating the array. Following that directive, I used the MS Disk Manager to define the partition and format it. Moments later RST initializes the array while the partition is being formatted. Hence, the array initialization is running concurrently with the partition format. Those action proceed without error for a couple days and finally stalls out with the array initialization at 69% and the partition format stalls at the same time at about 16%.
The correct procedure is to ignore what RST tells you to do after defining the array. First define the array with RST. Second leave you computer alone and it will begin the array initialization on it's own. Wait for that to finish. It took a couple days for me. You can monitor the status of RST and find something to do until the array initialization reaches 100% and finishes. Third, you can partition the array and format the partitions. When the format(s) are completed, the array is ready to use. Oh, a reboot is required between steps.
Remember that even if you define your array to as Raid 5 or 10, you still need to backup everything. Don't forget to test system recovery, because an untested backup/recovery strategy is usually worthless.
DArce
Thank you, we appreciate your feedback on this, it is really valuable for any similar issues.
