Server Products
4953 Discussions
Replace battery of cache-memory module AXXRPCM3
PPedr2
The reserve battery of cache-memory module AXXRPCM3 (RAID controller Intel SRCSASJV) as broken down.
Than it is possible to replace it (only the battery)? What analogue or compatible?
Thank's.
David_A_Intel
You should be able to replace the cache memory module only; there is no need to replace the entire RAID controller for this.
You may also consider installing a Mini-DIMM module for caching purposes instead; and then, install a Intel® RAID Smart Battery AXXRSBBU3.
