Server Products
4762 Discussions
Replacing Intel RAID RS3DC080 Controller - Will current RAID configuration be lost?
CSand16
We have a failed RS3DC080 controller connected to RES3FV288 expander. If we replace RS3DC080 with same model controller, will we loose RAID configuration?
Thank you!
Chip
JoseH_Intel
Hello CSand16,
Thank you for joining the community
If the issue was detected on the RAID controller and it will be substituted using the exact same model, the configuration should not be affected due to the fact that this information remain on the HDDs, not on the RAID controller.
Bear in mind that you should install the new RAID controller using the same cabling positions.
Hope this helps
Jose A.
CSand16
Thanks for information and taking the time Jose. Just what I needed to confirm. Your support is much appreciated!
Chip
