Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4659 Discussions
Right Server ??
Dear All,
I am having 25 Intel based Desktops with 256 MB RAM . I want to have a Xeon Server now . Kindly suggest me . How to choose a right processor . RAM & WHY ?? means with reaosn . So that i can help others . Assumes that my basic server knowledge is OK .
Amit
JLodh
New Contributor II
Hi Amit,
I assume you have 25 desktops and now you want a server to provide managed services for these desktop, very well!
Well first, choosing the right processor and RAM - Remember that be it microprocessor, RAM, HDD, motherboard, all these major components are chosen on some basis depending upon what exactly you're trying to achieve just like the rest of the components of your system. For instance, I would never suggest you to go for a 7000 series processor with lots of RAM in case you are setting up a server that does not require much compute intense applications/services to be hosted on it when you can live with a low end server processor and sufficient memory.
Secondly, configuring a server according to your needs ... here is a URL you might find useful:
http://serverconfigurator.intel.com/ Intel Server Configurator Tool
Additionally, you can choose a processor and/or motherboard that suits your needs.
With http://processorfinder.intel.com/ PROCESSOR FINDER TOOL, you can choose a server processor (Itanium/Xeon) and further select the options you want a processor to be capable of, e.g. Virtualization, Demand Based Switching, 64-bit capability, etc etc.
Further, to find a suitable motherboard, you can either look up the compatibility list for the selected processor or individually select a http://support.intel.com/support/motherboards/server/ SERVER MOTHERBOARD that fits your needs or http://mbsg.intel.com/mbsg/default.aspx find one that suits your requirements.
To do a compatibility check, though you have the compatibility list available for each processor/motherboard but still http://processormatch.intel.com/CompDB/ PROCESSOR MOTHERBOARD COMPATIBILITY TOOL is a plus.
Now, Amit ... to configure a server according to your need, you first have to provide us the details of the following if you want us to help you otherwise following the steps above, you can always configure one according to your needs:
  • Services you are planning to host on that server.
  • Network bandwidth considerations.
  • Hard drive capacity.
  • Memory load.
  • Processing load.
So you see, these are just a few of those considerations you need to keep in mind when configuring a server.
Warm Regards,
Javed Lodhi
Intel Go Green, Save The Environment!
