Server Products
4784 Discussions
S1200BTL Beep Code Help
NNaic1
Hi Guys
I have a intel s1200btl server board that does not boot.
I receive a beep sequence 1 5 4 4. What do i need to do to resolve the issue?
The 1-5-4-4 beep code sequence means that there is an issue with either the power supply or the power distribution board. We suggest testing the board out of the chassis over a non static surface with a regular ATX power supply to narrow the issue.
