Server Products
4778 Discussions
S1200BTL unlisted Error Code at boot - ran smoothly for 2 years
SvanS
Hi
My S1200BTL board in an Intel server chassis refuses to start up today.
The error code (with an amber warning LED) is 0xEA (1110 1010), which is not listed.
The boot process will not advance.
Any ideas?
Steph
Salem_W_Intel1
Hi!
I confirm 0xEA may be caused by a memory-related situation:
"The range {0xE0-0xEF} of POST codes is used for memory errors in early POST. In late POST, this same range of POST code values is used for reporting other system errors." (qtd. on page 31 of the http://www.intel.com/support/motherboards/server/sb/CS-032382.htm Technical Product Specification)
Since yours is a system that's worked for 2 years, I'd then recommend contacting our http://www.intel.com/p/en_US/support/contactsupport Technical Support.
