hello,
Last week I bought a new S1200BTLR motherboard and use a Xeon E3-1230V2 with it.
When I switch it on, after 5-6 seconds the status led blink orange and diag led show 0111-0000, then it stay like that without anything on screen.
Motherboard PBA is E98681-352 and should be compatible with the E3-1230v2
When i remove DIMM from the MB i get me some beeps.
I try the CPU on other MB and it work fine.
need some help
thanks in advance.
What kind of memory are you using?
hello Edward
I'm using a Corsair DDR3 Memory kit : CMP16GX3M4A1333C9
http://www.corsair.com/dominator-with-dhx-pro-connector-and-airflow-2-fan-16gb-triple-channel-ddr3-m... http://www.corsair.com/dominator-with-dhx-pro-connector-and-airflow-2-fan-16gb-triple-channel-ddr3-m...
Seems it's non-ECC DIMM. The board requires ECC DIMMs. See the http://www.intel.com/support/motherboards/server/sb/CS-032418.htm Tested memory and hardware list for supported DIMMs. But ignore the Registered DIMMs in the list - the board supports unbuffered DIMMs only.
Hi Edward
I get some new ECC DIMMs and it work fine
thanks a lot
