Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4548 Discussions
S1200BTLRM & Intel RAID RMT3PB080 - no RAID BIOS
Hi!
Please help me!
On boot I can't get into the RAID-BIOS and the controller is not recognised by server 2012. The BIOS is not showen on startup, the onbaord RAID-BIOS works
Systemoverview:
Intel S1200BTLRM - Bios 41
CPU: Xeon E3-1245V2
RAM: 8GB
RAID onboard OK - System Server 2012
RAID controller RMT3PB080 (even RMS25KB080) can not be configurated - should be used for a file server data partition
RMT3PB080 Package sais that the controller could only be user in Intel Server Board with E5 Xeon, but the controller ist listed in the S1200BTLRM compatibility list.
Version Numer lt. package: G34893-601
Pack-Date: 20-SEP-12
Greetings
Philipp
Edward_Z_Intel
Yes the RAID module RMT3PB080 is compatible with S1200BTLRM... Did you try different slots? Did you disable Quiet Boot in BIOS?
