Server Products
4784 Discussions
S1200BTS CPU fan installation
KSchw5
I am trying to install a Big Shuriken 2B on my S1200BTS, but it requires the use of a supplied backplate. I can't seem to remove the backplate that is mounted on the board, so I can't use my new CPU fan.
Is it possible to remove the backplate from the board, or do I need to get a different CPU fan?
Thanks in advance,
Kai
KSchw5
After this has been resolved with Intel Support I can shed some light on this.
As it turns out I was sold the rack version of the S1200BTS, which has a backplate glued onto the backside of the board.
Although it is not recommended by Intel to try and remove the backside it is possible if you are careful.
The heatsink fits nicely to the board.
Thanks for your help.
Silvia_L_Intel1
Xendor, I will move this thread to the server's community in order to get assistance on your question.
David_A_Intel
You should be able to remove the backplate support for the heatsink. I could not find any previous records about other customers using your heatsink with this board model.
KSchw5
